Hello all,
I have an active pipe network with structures, and I have an XREF surface. I want to reference the surface in the manhole structure so the structure uses the appropriate rim elevation. But when adding the structure it doesn't let me reference the surface.
Any help is appreciated,
Thank you,
Solved by troma. Go to Solution.
It didn't seem to work actually...
Please see the attached image.
I created the data shortcut, but still there isn't a surface to refernce to, even though there is a surface in the data shortcut.
Mark Green
Working on Civil 3D in Canada
In your screenshot it looks like there are no surfaces in the current drawing.
Mark Green
I figured it out.
I had to right click on the data shortcut surface, then click create reference, then copy. Now it works!
-Maybe that's what you were implying to do when you asked if it was refernced in?
Previously, I had XREF the file in that the surface was located, and that didn't work. I had to copy it in, through the data shortcut.
Mark Green
I like your idea for making shortcuts by browsing and picking a file. It is frustrating to know the data you need is right there in a file before you but you can't get at it due to the "one direction" work flow for shortcuts. Still we would need a shortcut tree for sharing data between project drawings in cases where you don't want to go looking for a file or if you are not sure which file has the data you need.
I haven't used Idea Station so I don't know how to vote. I don't see a way to vote from within the thread.
Mark Green
