Hello, if someone would please help me that'd be fantastic. I currently have my drawing units set to a precision of four decimal places.
However, in my properties window, the length is displaying without the zeros to the right of the decimal.
Any help is greatly appreciated in resolving this. I would prefer to see "537.0000"
Solved by EliANewlines. Go to Solution.
Is something wrong with your Drawing Units display if you look at the Sample output very clearly you can see other is no zero decimal in the output. I will upload mine so you can see the difference
Can you check the drawing setting? units and zone tap
try to restart your application
This is controlled by your current dimension style. If your current dimension style suppresses trailing zeros, properties palette will too, and vice versa. You can override the dimension style by changing the DIMZIN variable to 0, but this will put style overrides on your current dimension style.
I noticed that too. The DIMZIN = 0 fixed it. It was set to 11 for some reason I'm unaware of.
