Civil 3D Forum
Polylines (contours) isolaltion
4 REPLIES 4
726 Views, 4 Replies
Is there a simple way in civil 3D to isolate a ployline (contour) on a specific elevation?  All of the contours are on a Major and Minor layer, but I need to isolate contours on a specific elevation.  Help!!!  Thanks for any reply.
4 REPLIES 4
peterfunkautodesk
Add a "User Defined Contour" at the elevation that you want and turn on "User Defined Contours" in you style. These could also be extracted from the surface to make polylines.
Cheers,
Peter Funk
Autodesk, Inc
Peter Funk
Autodesk, Inc.
Adam_Farnsworth
Could you right click and use the Quick Select with the Object Type set to Elevation and the Properties set to Elevation?
Windows 7 x 64
ATI Radeon HD 5700 Series
12 GB Ram
i7 920 @ 2.67 GHz
Civil 3D 2011, 2010, 2009 and occasionally 2008 still (unfortunantly)
Adam_Farnsworth
Peter's solution is for if you're dealing with a surface, mine is for if you just have polylines.  Hopefully one of these works for you!
Windows 7 x 64
12 GB Ram
i7 920 @ 2.67 GHz
in reply to: Adam_Farnsworth
Thanks much.
Rail Community
