Hola!
I'm using civil 3D 2012 for 2 weeks now. When I create a query to include or exclude points in a specific point group I get an error. It doesn't allow me to build a query with decimal number but only with natural number.
Everything was fine with my old civil 3D 2011.
The problem is with civil 3D 2012? or maybe their is a magic switch somewhere to allow me to use decimal number?
Thanks for suggestion to resolve my problem.
Etienne
My propduct is up to date.
I get the same error with every drawing in 2012.
When I try to enter something invalid in the point group properties like this:
with elevations matching : <0.5
a message in the command bar appear "Le type ne correspond pas. (point elevation <0.5)"
or
with elevations matching : <blablabla
a message in the command bar appear "Le type ne correspond pas. (point elevation <blablabla)"
It's weird to have a French sentence in an English version of Autocad. Never saw that before. Maybe because I have a French version of Windows xp 32. Maybe I should update something special in my Windows OS?
Why would you have elevations less than 0.5'? Is this subsea?
Yes, I'm working with bathymetric surface.
I use "point groups" to divide points in different categories with different Point Label Style:
-above zero : with elevation >0.05
-near zero : with elevation between -0.05 and 0.05
-below zero: with elevation <-0.05
My temporary solution is to use the Qselect tool and assign Point label style manually.
Decimal number .05 is working with Qselect tool!!
Eti
