It's surprising how many of these posts go unanswered. I'm new to Part Builder. I only got started on it about a week ago. It seems to me that the answer to the initial question is to set a 2d point at your insert point in the top plane and make it fixed. Make a 2d line through the point as a layout line and make it fixed. Constrain your structure walls parallel and perpendicular to the layout line and the one wall coincident to the fixed point. Dimension your structure to the layout line and the fixed point. And finally set your autolayout point at the fixed point.
Thats because none of us know how to use it.
Joe Bouza
Thats because the documentation on it is sketchy and the tutorials available are limited. It's not rocket surgery but its close. I have about 20 hours logged on Part Builder and through trial and error was able to successfully make two arch pipe part familys with all the commercially available sizes for RCP and CMP. The tricky part for me was understanding the model variables and the size parameters. Constraints and dimensions were also fun but not too tricky. I'm a Civil Engineer but I have done quite a bit of programming and know a little XML so that helped.
You have invested your time wisely, and I m sure it will payoff with the PB. I shold piut more time into it. Thanks for the motovation.
Joe Bouza
Cool.
Feel free to contact me if you run into a roadblock. My email should be visible in my profile but if not, its mpara@bh-ba.com.
