Dan,
Something does not sound right regarding this dataset. The choice of the
template should not result in the instablity that you describe. The
default acad.dwt will simply create the "standard" set of necessary styles.
Also, we have tested the parcel topology with as many as 11,400 parcels.
I am very interested to see the dataset that results in the degradation of
performance that you describe. Please email me the LDD dataset for further
investigation.
thanks,
Daniel Philbrick
ISD Civil Development
"danbonenfant" wrote in message
news:25189757.1075728282514.JavaMail.jive@jiveforum2.autodesk.com...
> Civil3d - Service Pack 1
> When I try to import a few (140) parcels from LDD into Civil 3d using the
default acad.dwt template the system locks up. New drawing using _Autodesk
Civil 3D Imperial By Layer.dwt parcels will import but very slow. Shouldn't
the software create the objects it needs when working in a drawing not
created by Civil3d?
> Also working with parcels is very, very slow. Almost unusable with this
many parcels. Could you imagine working with a large project.
