I made new label style in label style composer (Civil 2012).
1. How to set point import to load points by default in this new label style?
2. How to save that label style?
Regards.
I am assuming you are creating a new point label style? In your toolspace/Settings right click on Points and select Edit Feature Settings. In the dialog box you can set the default point style and point label style under Default Styles. If you are importing points then I would also recommend setting up a Description Key Sets under Points File Format.
Tony Carcamo
President/Owner
Civil CAD Learning Solutions
DFW BIM Infrastructure User Group
LinkedIn | Twitter | Instagram | DFWBIUG |User Group
