I made section views, in which I want to show corridor and the existing ground for earthwork calculations, but these sections are not showing me the corridor, even though I have checked its settings, a tick is placed in front of the corridor, but it is not visible. I have also made sample lines again, but it has not solved the issue.
The CAD file is attached. You can see them.
Thanks in Advance. 🙂
Solved by Jeew-m. Go to Solution.
You have not sampled the correct corridor to section views.
https://www.youtube.com/watch?v=7uh-ZF__2_g
