I have created an assembly for my main road. I have daylight lines set and they are correctly doing their job. The problem is, the CL is following the existing ground surface, but from the curb to the daylight line, it is following the proposed profile. How do I fix this?
Solved by dbennettMQJY6. Go to Solution.
What did you use to define the corridor surface? for starters< I suggest only using the top link option and select break line overhang toggle
Joe Bouza
I was able to use the Top Link and got rid of the Daylight that was in there. I recreated the corridor and it is still doing what it did before, just not as bad this time. Where is the breakline overhang toggle located?
keep going: check add breakline and the pop down for overhang correction. I forget the specific name but it will make sense when you see it
Joe Bouza
Thank you for your help so far. So that fixed one side of my corridor, but the other side is still screwed up. It is now showing a proper representation of what I am seeing. There appears to be a daylight set to my back of curb that is daylighting towards the CL of the roadway tying into the existing profile still. For the segment that would be a cut daylight, it is making the contours follow this daylight. For the segment where it would be a fill daylight, the fill daylight line is still visible, but the contours are following the proposed grade. Weird.
Here is the drawing so you can better see what is going on.
Bests,
Hey there. Just wanted to let you know that I solved the problem. I recreated the assembly and there were no issues. Not sure what the problem was with the other assembly though. Thank you for your advice and earlier fixed.
Bests,
