Civil 3D Forum
Importing points using depths from OGL
9 REPLIES 9
Message 1 of 10
wilsonm2000
1357 Views, 9 Replies
Hi
We have a points file to create a "bottom of peat level" surface.  The only problem is, along with the X and Y, it only gives us the distance from OGL, not the actual Z Elevation at each point.  How do we import these into C3D to create a surface?  We have a topo survey for the whole site, so we have and EG surface.
Cheers
Martin
9 REPLIES 9
Message 2 of 10
wfberry
in reply to: wilsonm2000
Perhaps you can get the "distances" in your point file as descriptions with "0" elevations.  Once in the drawing you can have them "hop" to the Ex. ground elevation of the surface.
OK, now you are on your own.
Smiley Happy
Bjill
Message 3 of 10
wilsonm2000
in reply to: wfberry
Hi berry
sorry, I dont understand how I would do that.
Message 4 of 10
IanMcClain
What is OGL?
Ian McClain
Message 5 of 10
wilsonm2000
in reply to: IanMcClain
@IanMcClain wrote:
What is OGL?
Original Ground Level
Message 6 of 10
wfberry
One never knows about the experience of the person asking questions without some guidance.
I am assuming you know how to import your points into the drawing.
1.  I always insist that when importing points that you have set up a point group for them.
2.  Once these points are inserted and are happily appearing in your group, select the first row (or any row) and use the Ctrl key and the A key simultaneously.  All the points are selected.
3.  Right Click this highlighted group in the window and select "Elevations from surface".  All points are given the elevations at that location on your surface.
Now all you have to do is subtract the distances in your description to get the elevation you desire.  Maybe export points out and correct in Excel, import back in.
Bill
Message 7 of 10
wilsonm2000
Great, thanks for that.  I know how to do all those steps, its the "subtracting the distance in the description" I do not understand, how do I get each point to move according to the individual descriptions?
Thanks again for your help
Martin
Message 8 of 10
wfberry
I was hoping that someone may have this in a lisp or something.  But here is what I would do.  By exporting these points after they have been adjusted to the existing ground elevation, it seems that you could put these points, etc in individual columns in Excel, then have the "numbers" in the descriptions subtract from the newly acquired ground elevation giving you elevation points for your new surface.
Then save these points (Pt number, X, Y, Elev) in a new ASCII file and re-import.  Either delete all your old points or have the new one overwrite them.
Bill
Message 9 of 10
neilyj666
The correct (?) way to tackle this problem is as follows (I do this regularly for this very application)
  1. Ensure that your peat spot levels are positive and cover the whole of the OGL or area of interest - turn on triangles and add lines extra points etc etc. If the levels are negative then the technique below will add the levels to a surface which is a techniquie I use to add spoil mounds to a surface.
  2. Then create a volume surface with the peat depths as Base and OGL as comparison surface (see screenshot).
  3. Do a few checks using the tootips and you'll find be able to verify that the surface has built correctly.
  4. Create a new surface and paste the Volume surface into it - this turns it into a regular surface that can be added to profiles, corridor targets etc etc.
  5. It also remains dynamic so if additional site investigation points are added to the peat depths surface the base of peat level surface will update as well.
  6. This ensures that the base of peat mirrors the undulations of the ground which in most instances is fine but if there are many ditches then the base of peat will be a distance below the ditch.
  7. This technique can be used for most glacial type deposits but probably wouldn't be so good below rockhead (although could be useful with caveats).
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 10 of 10
wilsonm2000
in reply to: neilyj666
Brilliant, thank you so much Neily 🙂  yet again, you have helped me lots.....
Rail Community
