I am modeling a wet pond with permanent pool elevation of 1056. Bottom of pond is 1049.
The total outflow shown at elevation 1056 is 652.76 CFS. This is obviously wrong, but I do not know what I am inputting incorrectly to cause this. Any suggestions are appreciated.
Solved by fcernst. Go to Solution.
Can you attach the file. I'd like to see if it runs correctly in 2019 with the latest patch...
It does not appear to let me attach the file.
If you email me at Michael.secgroup@gmail.com I will respond with the file attached.
When I hit "Done" it immediately updated. See attached file.
Thanks. There is definitely something else going on.
When I hit done on my file, it does not update.
Also, every time I click compute on the outlet tab the total outflow increases at each stage. This is true when no other input has changed.
It sounds like you may have not applied the patch for Hydraflow that came out a couple of weeks ago...
