I found this while working on a new project: I created a Hydrographs file and then created an Express file to size a culvert.
The hydrograph matches all the same data for both programs, but the Express version is not calculating the time of concentration properly for the Channel Flow segments.
See the image below:
(H is the hydrographs file, E is the Express file)
I have the same data in a spreadsheet I've been using for years and it gives me the same figures as Hydrographs. I thought maybe Express wasn't converting the Tc to minutes, but 2.6 minutes is 0.0433 hours, so I do not think that is it.
I've reported this, but just thought I'd let everyone know about this issue.
Adam Reilly
Dell Precision 55400
Windows 10 Pro
Intel Xeon E-2276M 2.80GHz, 64bit
NVidia Quadro T2000 Mobile/Max-Q
Austin CADD User Group
Solved by fcernst. Go to Solution.
Hi @AdammReilly ,
Thank you for posting this. Do you have a case number or defect ID?
It looks like the flow length in Express is only 3.77 feet..
I finally found that after most of a day grumbling about it lol. And I only noticed it because I started another model that calculated correctly.
I need a vacation 😫
