HOW CAN I EXPORT USER DEFINED COORDENATES SYSTEM (DOSE NOT HAVE CODE)?
TO BE IMPORTED AND USED IN OTHER PC's.
THANKS IN ADVANCE.
Solved by rl_jackson. Go to Solution.
You should be able to save the drawing with the CS and then the other person opening the file with be informed of the new CS and asked if they want to save it to their library.
Now, @Pointdump and myself ran into an issue with that can be found here:
Rick Jackson
Survey CAD Technician VI
Hi Salah,
More information please on what you have. Can you post your drawing?
Dave
Dave Stoll
Las Vegas, Nevada
I WANT TO EXPORT USER DEFINED COORDINATES SYSTEM AS XML, SO OTHER COLLEAGUES CAN IMPORT IT AND USE IT
WHEN I USE MAPCSLIBRARYEXPORT, IT ASK FOR CODE
<<...SO OTHER COLLIGUES CAN IMPORT IT AND USE IT...>>
What's the program the other colleagues area using?
AutoCAD? Arc Pro? Something else?
Set a drawing to your new system, save the file and then have the other users open that drawing. It will request to add the CS to the library, just as I stated in my post #2
Rick Jackson
