Civil 3D Forum
Error Messages
4 REPLIES 4
343 Views, 4 Replies
Error Messages
When I run my corridor I get an error message that says "Failed Target Not Found" it is for the subassembly provided by WisDOT called UrbMedian.  Any ideas?
4 REPLIES 4
sboon
This is a standard error message that comes up when a corridor is unable to locate a surface target.  Did you select a target surface for this subassembly?  Is your surface large enough for the corridor to find it?  Do the files from WisDOT include a help file for this sub?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
in reply to: sboon
This sub only has the option to set targets for both offset/width and elevation/slope.  I have targeted an alignment and a profile.  There is no option to target a surface.  Attached are the help files from WisDOT for this subassembly.  This is the only subassembly I having an issue with.  It also doesn't show up in my section editor.
peterfunkautodesk
Do you get the error message at every station or just a few? If it only for a few stations, does the alignment/profile exist at the station? The other thing to check is that the target alignment is on the correct side of the main alignment.
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
in reply to: peterfunkautodesk
I get the error message at every station.  What do you mean by check that the target alignment is on the correct side of the main alignment?
Rail Community
