hi guys
i have one problem with autocad civil 3d
Most of the time i put lots of efforts to make drawing in paper space using vp, when every thing is appered to be ok and i have printed the same, After some time the scale of Autocad civil 3d objects (all those which are generated by Civil 3d) gets changed(in paper space).
in starting i get very upset.
but now what i do is that, i copy the same layout to onother new layout and every thing seems to be ok.
plz help me ... i m not doing anything then how its happen every time?? and kills my time lot.
i have attached the screenshot.
1. when every thing is appered to be ok ---screenshot no1
2. gets changed(in paper space).---screenshot no 2
3. copy the same layout to onother new layout and every thing seems to be ok------screenshot no 3
Rick Jackson
Survey CAD Technician VI
no bro i always used to lock the vp.
u can see , may be it is not locked (assume), then how it becomes corrected after copying the same layout (by clipboard) to the new layout??
Rick Jackson
dont know what is happening
i tried plz see the screenshot in properties for both VP annonation scale is 1:5000
Make sure you set UCSFOLLOW to 0. Set it in paper space, and activate the viewport and set it to 0 there as well.
You only mentioned copying the layout. Does a Regen-all help?
Allen Jessup
CAD Manager - Designer
Rick Jackson
Thought I'd try something easy. Sometimes we forget easy. Would it be possible for you to post a drawing with one layout that has problems and a copy that is good? I've never had a problem like that where a regen wouldn't fix it. Without looking at an actual drawing I'm out of ideas.
Allen Jessup
Use the command PSLTSCALE and set the perameter to 0. I know this is years late but maybe it will help someone else.
