Civil 3D Forum
CS Conversion while importing DEM
2 REPLIES 2
168 Views, 2 Replies
I am importing a DEM file using the new civil tools in Map 2005 (same as Civil 3Dusing the import DEM command. I expand my civil workspace to DEM Files, right-click, and choose add. Then I pick my DEM file and set my coordinate system. When I click OK I get the attached message:
Also, I have tried starting a new surface. If i create a new surface and set all of the settings mentioned above, I click OK and nothing happens, just leaves me with no DEM data.
No on in the Map NG has replied so i am wondering if any of you have any ideas?
Jeremiah
2 REPLIES 2
Are you trying to add the DEM to a Grid surface or a TIN surface?
Try adding it to a TIN surface if you haven't.
This is from the 2004 readme (which would apply to Map 3D):
DEM Files Cannot Be Transformed for Grid Surfaces
To perform a coordinate transformation on a DEM file, include the DEM file as part of the surface definition data for a TIN surface. When you add the DEM file, you can specify the DEM file's coordinate system. If different than the drawing's coordinate system, a transformation of the coordinates is performed.
If you include a DEM file as part of a Grid surface definition, its coordinate system must match that of the drawing, or it cannot be added.
-Karla Leighton
Autodesk Technical Publications
I am only using Map 3D, not land desktop.
Rail Community
