I've been researching the options to deal with tessellation of my corridor. I see the option to extract feature lines from the corridor and to maintain a dynamic link.
I've now found a link in the docs for converting tessellated lines to arcs. Can I use this command with a dynamically linked FL? And will it maintain the dynamic link?
http://docs.autodesk.com/CIV3D/2012/ENU/filesCUG/GUID-BE13F766-B372-4564-B9AF-5B7A5526EA8-1066.htm
Don Ireland
Engineering Design Technician
You'll notice that when you select a linked feature line the Modify Geometry tools on the ribbon are greyed out, so, no, you won't be able to fit curves on that object.
