Civil 3D Forum
computing pre development calculations
2 REPLIES 2
232 Views, 2 Replies
What is the best method for computing small site pre development and post development rational method calculations using AutoCad C3D?  I have used SSA and Hydraflow Hydrographs and pencil and paper.
2 REPLIES 2
and my help doesn't populate from either the question mark or the pull down menu. Any Help?
annw2
If you are using rational you are sizing pipes and the Storm Sewer program works well.
I start with drawing the poly lines to determine the catchment area.  I use the parcel function to measure and label the areas.
I haven't had much luck with the catchment function as you can't merge areas
I use bpoly to determine how much of the drainage area is impervious, etc.
I have spreadsheet to determine CA values and another for time of concentration.
Did you have a more specific question?
Ann Wingert, P.E.
Rail Community
