I know how to change the elevation of an entire surface, ie reduce z with 0,5 meters for all points, but I want to change the elevation a little in some areas and a bit more in some others. How do I do that?
Typically I have a surface for the ground level. I want to lower (copy) this surface to represent a soil layer. I have a number of soil sample points in which I have x,y,z for the bottom of the current soil layer. Between the samplepoints I want the soil layer to "follow" the ground level. Example: I have one point with 0,5 meters of sand and the next point (50 meters away) with 1 meters of sand. The two points are on the same ground level but between the two points the ground level varies a lot (±2 meters). A straight interpolation between the two points would have the bottom of the sand layer going over the ground surface.
You might say I want to "drape" the ground level on the sample points.
I hope you understand what I want to do?
Solved by neilyj666. Go to Solution.
I'm am not totally clear of your objective, but I can say that this sounds like a job for Feature Lines. These can be draped on a surface, adjusted as needed and then added to a surface as breaklines.
Tim
Create a surface from your sampled xyz points- ensure that the depth is positive. You may need to add dummy points to extend outside the current surface
Createa volume surface with the sample points surface as base and current surface as comparison
Create a new surface and paste the volume surface in.
neilyj (No connection with Autodesk other than using the products in the real world)
