When using the analyze/area command I can snap to 3 points and then it will not recognize anymore snaps.
It will work fine when just clicking freehand with no snaps. So I end up turning off my snaps and zoom
in really close to the end of the line to get my area. Really annoying as I am a surveyor and deal with tons
of areas everyday. Any ideas? Thanks for any help.
Josh Ellis
Nu-South Surveying
Anderson, SC
using CV3D 2 years, still overwhelming:)
Solved by BrianHailey. Go to Solution.
I can't reproduce that issue. What version of Civil 3D do you have, what service pack do you have installed, and does that also happen in new drawings based on original AutoCAD templates?
- alfred -
You're snapping to 3D points. The area command can only calculate an area in a single plane. Change your OSNAPZ system variable to 1 when doing areas and change it back when done.
if Brian is correct (a good chance he is, great catch), I want to add one important info to his video:
One of my most used sentences during trainings: "AutoCAD is communicating with the user" ... and also within the _AREA command and the 4th point with different Z-value you get that communicated:
That info describes why it's not taking the point.
- alfred -
Sorry for not responding faster. I didn't receive the emails. That was the problem! Thank you sooooo much for your help. I had been dealing with that for 2 years! We draw a lot of subdivision plats and it was extremely frustrating. This forum has been a absolute life-saver. Thank you all for the help.
Josh Ellis
Nu-South Surveying
Anderson, SC
