I'm trying to come up with an alignment station&offset label that labels a gutter elevation. When adding the profile reference text to the label style, I do not see any expressions appearing.
Any ideas?
thanks
Solved by jmayo-EE. Go to Solution.
Did you make an alignment expression or a profile expression? I believe it needs to be a profile expression. If that is not working I might try an alignment expression.
John Mayo
Yep. it needs to be in the "profile_major_station expression" node.
Thanks!
