2020 C3D: Mapexport command brings up a dialog box showing the tabs but no fields. I repaired once and reinstalled twice to no avail. Please advise.
What if you grab the top of the dialog and move it? Does it refresh?
Thank you for your response tcorey, regrettably the dialog box did not refresh or regenerate after being moved. This particular issue is reoccurring after two re-installs and one repair. FYI System properties are Intel(R) Xeon(R) E-2174G CPU @ 3.80GHz 3.79 GHz (Processor), 64-bit OS & x64 based Processor (System type), 31.8 GB usable Ram. I think hardware can be ruled out.
@tcorey wrote:What if you grab the top of the dialog and move it? Does it refresh?
