Hi all,
I'm trying to create curb returns etc using the intersection wizard. I don't mind whether or not the extension for the incoming & outgoing lanes are shown, I just want to be able to make the tangent point of the curve station 0.000!!! Any advice on how this can be done would be most appreciated.
Thanks in advance,
Michael
Solved by Jeff_M. Go to Solution.
myCAD1975, as you can tell from the lack of responses, this group is not frequented by too many users. We discuss programming for Civil3D using lisp, VBA, VB.NET, C#, etc. here. For more general C3D questions you should place them in the main C3D forum: http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/bd-p/66
To answer your question, create the alignment then go back and change the reference station to where you want it to be:
