Show only
Search instead for
I need to simulate swirling flow exiting a fan as it enters the pipe downstream. The flow has strong swirl as a function of radius. Am I asking the right person at Autodesk?
The following would allow this to be done with Autodesk CFD in a narrow sector of the pipe, such as 30 or 45 degrees:
1. Allow flow through the two slip surfaces, but make the thru-flow equal at every corresponding point.
2. Allow a user-defined BC that allows me to use a math function to specify the magnitude and flow direction at every point on an inlet plane OR same as a function of radius from the central axis.
So far, I have not figured out a way to do this analysis using Autodesk CFD. It is turning out to be a =our main application, so it is of a lot of concern here.
Hi, I am not really the right person to ask as I don't work for Autodesk. I suggest you create a post in the forum instead. What I can tell you is that as far as I know it is not possible to create user-defined BC, however it may be possible to achieve what you want with some workaround.
@tnorrisPHCWD - Paul is correct here: you'd be best served by movign your question to the Forums and not here on Ideas (which is targeted for feature reuqests).
That being said, look at our Periodic BC as this may be what you are looking for in #1. For #2 we can do velocity as a function of radius or with a linear PWL variation along a given direction (check the help on this)
@PaulNielsen - Are you asking for slip (sans Sym) for purpose of radiation models? or is there another rationale for wanting Slip without Sym?
