Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
214 Views, 4 Replies
XREF Titleblocks
I am trying to make all of my company's tblocks use xrefs for the borders
and our company info. I am somewhat of a newbie to using xrefs, so please
bear with me.
I made a drawing of the border, etc. to use as an xref (X-GNRL-AANL)
I made a wblock of the tblock attribute info to insert into the template
(GNRL-AAN-ATTB)
I then created a dwg template (GNRL-AANL) with the inserted xref and
attributed block in order to minimize the steps when inserting a paperspace
layout.
The reason I am wanting to do it this way is to bypass having to make, or
import any page setups, other blocks, etc. I want one step (insert layout
from template) that will bring in everything.
When I open a drawing and "insert layout from template" the xrefed border
comes in as a block reference, not as what is shown when opening GNRL-AANL.
What can I do to accomplish this? Or do I have to bring the existing
drawing into the opened titleblock template drawing so that the Xref will be
shown?
using A2k.
Thanks in advance for any help!
Brandon
remove ~NS~ when replying.
4 REPLIES 4
When you say template, I think you mean just a library file that can be
inserted. This won't work without first attaching the xref to define it as an
xref, then you can erase that (or stop just short of final placement) & insert
your setup block. Perhaps a very simple lisp command or menu macro could do both
steps for the users fairly painlessly. Another step needed will be to turn the
viewport on, it will com in turned off. If you did set up a template (DWG saved
as DWT) though, that would work for the first layout at least & people could
just copy & paste to additional layouts.
here's sort of a rough outline for how it might go:
-xref \\servername\library\30X42.DWG
0,0,0 cancel
-insert *\\servername\library\SHEET.DWG
0,0,0 " " " "
mview on all
> bear with me.
> (GNRL-AAN-ATTB)
> layout.
> shown?
> using A2k.
> Brandon
Thanks for the help Paul. I am having a problem with the menu macro. When
it gets to the line about attaching the file it doesn't do anything. I have
a feeling it is just some little thing I'm not doing, but I wouldn't know
what it is due to my lack of knowledge about macros. I can write out a
simple command sequence, but not file paths. I'll give you what I got, but
I know the file path is wrong:
^C^C-xref;a;\\HOUSTON_BD1\APPLICATIONS\_ACAD\TBLK\GNRL\X-GNRL-AANL.dwg;0,0,0
;^c^c
One error message when I was trying to figure it out said---
Warning: If you are trying to attach the file: "X-GNRL-AANL": as an Xref, it
must be attached using the = syntax.
How do I make the macro read the xref path.
TIA,
Brandon
"Paul Furman" wrote in message
news:3A5B76B7.A8180468@edgehill.net...
an
insert
do both
the
saved
could
> 0,0,0 cancel
> 0,0,0 " " " "
> mview on all
borders
please
> > bear with me.
> > (GNRL-AAN-ATTB)
paperspace
> > layout.
or
layout
border
GNRL-AANL.
will be
> > shown?
> > using A2k.
> > Brandon
If you want to consider a third-party option - check out Titlezone, which
automates the whole xref border/block insert title process for you.
Best Regards,
Tim
Tim Erskine | erskine@codezebra.com
Code Zebra, Inc. http://www.codezebra.com
P.O. Box 342, Salt Lake City, UT 84020
800-356-2113
FlowTools Intelligent Diagramming
Titlezone Title Block Manager
OK, I figured it out. Forward slashes, not back slashes do the trick.
//Houston_BD1/App.....
"Brandon Cooley" <~NS~jbcooley98@yahoo.com> wrote in message
news:63D9E54F59CF247F161385F119556CFE@in.WebX.SaUCah8kaAW...
Administrator Productivity
