Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Windows 7 and the taskbar
3 REPLIES 3
Mistress0fTheDorkness
7884 Views, 3 Replies
So, we just upgraded to Windows 7 at work (finally). I always keep my taskbar on the right side of the screen, so that I can keep it wide enough to show the filenames. I have the AutoCAD TASKBAR sysvar set to 1. But, windows is stacking the entries, instead of displaying them all down the length of the taskbar. Can I change that?
(sorry, can't upload attachments here, see this post in the augi forums for a screenshot)
Melanie Stone
Facilities Data Management
IWMS / CAFM / CMMS / AutoCAD / Archibus / Tririga / Planon / MRI Manhattan CenterStone / Revit / data normalization, data mapping, reporting and process documentation
mistressofthedorkness.blogspot.com/
3 REPLIES 3
right-click on the taskbar and select SIDE BY SIDE option if I understtod your problem correctly.
Unfortunately, no, that's not what I'm going for... nothing to do with the application windows.
I just want the entries in the windows taskbar to appear separately, so the filenames are visible.
Melanie Stone
Okay, wow, I just finally found it... don't know why I didn't see it before...
Right click on taskbar > properties > Taskbar tab (taskbar appearance group) > Taskbar buttons: select 'never combine' from the dropdown.
There I go. I shoulda had a v8.
Melanie Stone
Administrator Productivity
