CAD Managers
CAD Managers
Distinguished Contributor
wsargent
Message 1 of 5 (4,196 Views)
Windows 7 64 bit, AutoCAD 2009 and Civil 3D 2009
4196 Views, 4 Replies
12-30-2009 05:57 AM
IT just purchased two new computers that are running Windows 7 64 bit. Our company uses both AutoCAD 2009 and Civil 3D 2009 on Windows XP 32 bit and I have the object enabler installed on AutoCAD to be able to see the Civil objects. I can not locate a object enabler for the 64 bit system. Does anyone know if AutoCAD 2009 64 bit can display Civil 3D objects? If not, has anyone else encountered this problem and found a solution? (I attempted to install AutoCAD 2009 32 bit on the 64 bit system but the deployment failed.)
Thanks in advance.
__________
AutoCAD Civil 3D 2012 (Primary), 2011 by contract.
Dell Percision T3500: MS Windows 7 64-bit SP1; Intel Xeon CPU W3505 @ 2.53GHz, 12.00 GB RAM, NVIDIA Quadro 600
*Dean Saadallah
Message 2 of 5 (4,196 Views)
Re: Windows 7 64 bit, AutoCAD 2009 and Civil 3D 2009
12-30-2009 06:35 AM in reply to: wsargent
There is no fix: 64bit OEs do not exist for R2009.
>>>... Does anyone know if AutoCAD 2009 64 bit can display Civil 3D
>>>objects...<<<
R2009 is R2009, whether 32bit or 64bit, it's off the same DVD from the same
production run, from the same code.
Dean Saadallah
http://LTisACAD.blogspot.com
*Dean Saadallah
Message 3 of 5 (4,196 Views)
Also, be aware of this fact:
http://worldcadaccess.typepad.com/blog/2009/03/no-april-fools-day-joke-autodesk-to-triple-upgrade-pricing.html
http://usa.autodesk.com/adsk/servlet/index?id=7176852&siteID=123112
Dean Saadallah
wsargent
Message 4 of 5 (4,196 Views)
12-30-2009 06:41 AM in reply to: wsargent
Then is there a way to install the 32 bit AutoCAD on the 64 bit system, so I can use the 32 bit OE?
__________
*Dean Saadallah
Message 5 of 5 (4,196 Views)
12-30-2009 09:08 AM in reply to: wsargent
No one has found a way yet... .
Dean Saadallah
Post to the Community
New Post
Announcements
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
