IT just purchased two new computers that are running Windows 7 64 bit. Our company uses both AutoCAD 2009 and Civil 3D 2009 on Windows XP 32 bit and I have the object enabler installed on AutoCAD to be able to see the Civil objects. I can not locate a object enabler for the 64 bit system. Does anyone know if AutoCAD 2009 64 bit can display Civil 3D objects? If not, has anyone else encountered this problem and found a solution? (I attempted to install AutoCAD 2009 32 bit on the 64 bit system but the deployment failed.)
Thanks in advance.
__________
AutoCAD Civil 3D 2016 SP3.0, built on: AutoCAD 2016 SP1, Map 3D 2016 SP2
Dell Percision T5810: MS Windows 10 Pro; Intel Xeon CPU E5-1620 v3 @ 3.50 GHz, 16.00 GB RAM, NVIDIA K2200 4.00 GB Memory
