Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Windows 7 64 bit, AutoCAD 2009 and Civil 3D 2009
4 REPLIES 4
wsargent
5703 Views, 4 Replies
IT just purchased two new computers that are running Windows 7 64 bit. Our company uses both AutoCAD 2009 and Civil 3D 2009 on Windows XP 32 bit and I have the object enabler installed on AutoCAD to be able to see the Civil objects. I can not locate a object enabler for the 64 bit system. Does anyone know if AutoCAD 2009 64 bit can display Civil 3D objects? If not, has anyone else encountered this problem and found a solution? (I attempted to install AutoCAD 2009 32 bit on the 64 bit system but the deployment failed.)
Thanks in advance.
__________
AutoCAD Civil 3D 2016 SP3.0, built on: AutoCAD 2016 SP1, Map 3D 2016 SP2
Dell Percision T5810: MS Windows 10 Pro; Intel Xeon CPU E5-1620 v3 @ 3.50 GHz, 16.00 GB RAM, NVIDIA K2200 4.00 GB Memory
4 REPLIES 4
in reply to: wsargent
There is no fix: 64bit OEs do not exist for R2009.
>>>... Does anyone know if AutoCAD 2009 64 bit can display Civil 3D
>>>objects...<<<
R2009 is R2009, whether 32bit or 64bit, it's off the same DVD from the same
production run, from the same code.
Dean Saadallah
http://LTisACAD.blogspot.com
Tags (1)
Also, be aware of this fact:
http://worldcadaccess.typepad.com/blog/2009/03/no-april-fools-day-joke-autodesk-to-triple-upgrade-pricing.html
http://usa.autodesk.com/adsk/servlet/index?id=7176852&siteID=123112
Dean Saadallah
wsargent
Then is there a way to install the 32 bit AutoCAD on the 64 bit system, so I can use the 32 bit OE?
__________
No one has found a way yet... .
Dean Saadallah
Administrator Productivity
