Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
What is the best software to transfer PDF image to an AutoCAD DWG?
8 REPLIES 8
Message 1 of 9
jatriassi
923 Views, 8 Replies
I am in a discussion group and when converting PDF to AutoCAD comes to the table there are no good answers. So that said, what is the best solution or software out there?
8 REPLIES 8
Message 2 of 9
in reply to: jatriassi
While a lot of PDFs do only contain an image, many often contain vectors
and some contain text.
Try the demos and report your findings. Here is a candidate to start
with http://www.dotsoft.com/pdf2dwg.htm.
Terry
Message 3 of 9
omc-usnr
2010 will allow pdf underlayment
Message 4 of 9
you assume the pdf has info you will like. Zoom in close to see that clean lines are not so nice like in Cad.
I tell people to convert to jpg via adobe acrobat full version ($300), then pull in image.
I don;t like using dwf or pdf underlay, as it just makes dwgs more fancy, with less compatibility, and less liklihood to
plot correctly. Stick to dwg's and images IMO.
jatriassi <>
James Maeding
Civil Engineer and Programmer
jmaeding - at - hunsaker - dotcom
Message 5 of 9
tony1978
I have used raster design by autodesk and it was pretty good.
 Tony Carcamo
President/Owner
Civil CAD Learning Solutions
DFW BIM Infrastructure User Group
LinkedIn | Twitter | Instagram | DFWBIUG |User Group
Message 6 of 9
oh, never noticed it could do that, i'll check.
That pdf to image conversion is a bottleneck for many things. We use Acroplot Repro for pdf to super nice BW tif's for
plotting on oce plotters. Tifs (or rasters I should say) are the only format for dependable plotting on other peoples
plotters.
tony1978 <>
James Maeding
Message 7 of 9
GilesPhillips
If the pdf contains vector data, then we use Adobe Illustrator to export this as a dwg- it'll then need some work to tidy it up, but is good for basic stuff.
If it's a raster image then simply export as jpeg.
ACad, MEP, Revit, 3DS Max
Message 8 of 9
taccomc
[www.PDFTIFF.com|http://www.pdftiff.com] it works great for converting multipage pdf into tiff but also will layout up to 8 pages of the file into 1 sheet for easy insert of engineering reports into your plan set. Try it for free. Edited by: taccomc on Apr 12, 2010 3:41 PM
Message 9 of 9
Kayrondad
in reply to: taccomc
best one we found and inexpensicve is Aide pdf to dxf converter
http://www.aidecad.com/, money well spent by us
Administrator Productivity
