no, group 4 does work and is the best compression choice for bw tiff.
We have an OCE scanner that does CCITT group 4 all day and I use Corel Photo Paint to do that compression too.
I also have a .net tool that does group 4, all with no acad problems.
There is some other issue with the tifs.
I have researched this issue of what color format is best for server space and AutoCad, and have concluded a jpg with
30% compression is best.
You cannot create "color indexed" drawings with jpg, or transparent pixels. Use PNG for those situations.
Even if you take a 24 bit color jpg, and convert to 256 color optimized palette (known as an indexed palette), the jpg
will be smaller with 30% comp.
You can get super compression with ecw files, but must pay to get the converter for files over 80mb I think.
So we use tif with group 4 compression for bw, jpg for all else.
Be aware that jpg is a lossy format, while tif and png are not. The compression of jpg is so good because of this
lossyness, so don't save a jpg 5 times in a row at 30%. Keep at 0% compression til you are done.
I usually keep a png original, then save to jpg when done tweaking.
I wish someone out there had written a better manual on this, its taken years of experience to settle on the best
options given all the image flavors and compression issues.
raysmith8525 <>
|>What color compressed image file works within Autocad? Our scanners create a group 4 TIFF, which is not compatible with Autocad.
|>We would like to change the default setting on the scanners for an image file that does not need converting before it can be inserted into a drawing.
|>Does anyone know if LZW type works? (The format my IT guy wants to use)
|>We are currently running LDD 2009, Raster, Civil, and Survey
James Maeding
Civil Engineer and Programmer
jmaeding - at - hunsaker - dotcom
