Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Using Excel to draw AutoCAD drawing
7 REPLIES 7
Message 1 of 8
10194 Views, 7 Replies
I will like to know is it possible to use visual basic as an interface where user can enter data using microsoft excel and all the data will be automatically updated in the autoCAD drawing.
Have anybody try it out before? Please let me know if it is possible and how this can be accomplish.
Thanks a million!
Andy
7 REPLIES 7
Message 2 of 8
That is something that I have tried but
could not figure it out completely and I really don't have time to redraw the
Dwgs I have with Rebis.  The Rebis software by Autodesk looks like your
best bet if you are creating new dwgs.
Filakia
Of course I don't look busy........I did it right the
first time.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
Thanks a million!
Andy
Message 3 of 8
This may not be exactly what you require, but it does provide a cool interface between Excel and AutoCAD via scripts. Check out http://www.scriptsheets.com/index.htm
JimL
Message 4 of 8
lyz77 wrote in news:f0b5f08.-1@WebX.maYIadrTaRb:
Have anybody try it
> accomplish.
Thanks a million!
Andy
I saved this a long time ago. If it worked with LT, it should work with
AutoCAD. Of course, change the "AutoCAD LT.dde" to probably "AutoCAD.dde"
and watch the line wraps.
--begin included message--
Robert Benjamins wrote in message
Here is a small example of a macro I use.
Sub Macro1()
kanaalnr = Application.DDEInitiate("AutoCAD LT.dde", "system")
x = Worksheets("blad1").Range("B5")
y = Worksheets("blad1").Range("B6")
lengte = Worksheets("blad1").Range("B10")
For L = 715 To lengte - 500 Step 500
Call TEKENGAT(x + L, y + 220)
Call TEKENGAT(x - 55 + L, y + 220)
Call TEKENGAT(x + L, y - 63 + 220)
Next L
Application.DDETerminate kanaalnr
End Sub
Sub TEKENGAT(x, y)
Application.DDEExecute kanaalnr, "[Line " & x - 7 & "," & y - 7 & " " & x +
7 & "," & y + 7 & " ]"
Application.DDEExecute kanaalnr, "[Line " & x - 7 & "," & y + 7 & " " & x +
7 & "," & y - 7 & " ]"
Application.DDEExecute kanaalnr, "[-LAYER S 1 ]"
Application.DDEExecute kanaalnr, "[Line " & x - 10 & "," & y & " " & x + 10
& "," & y & " ]"
Application.DDEExecute kanaalnr, "[Line " & x & "," & y + 10 & " " & x &
"," & y - 10 & " ]"
Application.DDEExecute kanaalnr, "[-LAYER S 0 ]"
End Sub
Indeed, Autocad LT must be running.
I normaly use my macro from Excel when I'm working in Autocad LT.
When Autocad LT isn't running, Excel asks if it should start Autocad. but
that always fails.
--end included message--
Enjoy,
Stef
mailto: yodersj@earthlink.net || Drafter, Leather-worker
http://home.earthlink.net/~yodersj/ || Dos, Win, LT
http://www.geocities.com/yodersj/ || Computer How-To
RFC 1855, section 3.1.1, item 10 at http://www.faqs.org/rfcs/
Message 5 of 8
You can do something like this using Oracle and Map. You can actually draw
the whole drawing from Oracle.
Also, you can do what you are talking about in Map, as far as attributes,
but I don't think it is a round trip deal in plain AutoCAD.
Jack Talsky
"lyz77" wrote in message
news:f0b5f08.-1@WebX.maYIadrTaRb...
> Thanks a million!
> Regards,
> Andy
Message 6 of 8
rameshpatel74
dear sir how to paste excel data in autocad command line using excel macros
Message 7 of 8
ahmadkandil
This may not be exactly what you require, but it is as easy as copy in excel...paste in autocad
https://www.udemy.com/draw-in-autocad-using-excel-data
Message 8 of 8
rufinascott
AutoCAD is highly compatible with Microsoft Word and Excel. You can insert a Word document into AutoCAD, you can insert an Excel spreadsheet into AutoCAD and you can insert AutoCAD images into Word and Excel. A procedure that is not done very often is inserting AutoCAD images into an Excel spreadsheet, but it is relatively easy.
Administrator Productivity
