This file was made by copiyng a line form an "infected" one.
After erasing it whats left it´s a bunch of unpurgeable textyles that spread like a virus.
Is there a way to eliminate them?
NOB
Look in the subscription center for DGN hotfix or something to that effect, I know they released one for Civil 3D 2013, not sure about ACAD though.
Try with Free batch tools available to download from Autodesk Exchange App store which has built-in command to purge the DGN-Linetypes from AutoCAD version 2012 to 2015
BatchInEditor - This would be useful for large amount of files which opens each file in AutoCAD, so user can add their lisp and script routines as well
BatchInDatabase - This would be useful if you want clean large amount of files without opening the files, takes less processing time
LayoutManager - Handy for current drawing opened in AutoCAD which has lots of Layout related commands including command to Purge DGN-linetypes
I´m uploading result images from the apps
They all kind of work the same way.
At the end of the process they say something like :Apllication does not support JIT debugging.
You may try the alternative method to remove the DGN linetype using BatchInEditor and this would remove the complete dictionary which may result in loosing of some entities which are using the DGN lintype.
1. Add the command "Lisp Expression" and copy and paste the below lisp code
(dictremove (namedobjdict) "ACAD_DGNLINESTYLECOMP")
2. Add Purge-All command
