Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Turn off layers in PDF plots via lisp
2 REPLIES 2
AOadmin144
751 Views, 2 Replies
Does anyone know how to turn off including layers in the export to PDF
I need to roll this setting out to everyone so I need a lisp or registry solution.
http://www.cadtutor.net/forum/showthread.php?64352-How-to-turn-off-layers-in-your-AutoCAD-PDF-Plots
2 REPLIES 2
JamesMaeding
in reply to: AOadmin144
I have never seen any api for editing pc3 files, which is where the setting is.
I can edit page setups, but that is as close as I have seen.
I bet if you find someone that does know of a pc3 editing api, you will be on the right track...
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
AOadmin144
in reply to: JamesMaeding
Already fixed the PC3 file
There is sheet set publish options, export to pdf options and users swear they are using Adobe Acrobat.
Administrator Productivity
