Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Turn off Digital Signature in Registry
5 REPLIES 5
1652 Views, 5 Replies
I want to use a registry edit to make sure that Digital Signatures are turned on our workstations. Can anyone point me to the registry key that controls that?
Keith
5 REPLIES 5
Keith, do you want to turn it on or off? Your subject line contradicts your actual post
Sorry you are correct, thanks for the heads up. I have already found the registry key to turn off the digital signatures by the way.
Jedimaster
I was curious if this will eliminate acsign load error. I know they suggest wiping AutoCAD and reinstall but I have done that on a machine twice
for other reasons and not looking forward to wiping it again.
lennart.losjo
Hi.
If you ask for help, and then later on find the answer your self, it would be nice if you post the answer here also 🙂
I also are looking for the registry key for turning off digital signatures.
Regards
Lennart
jeff.arbogast
HKEY_CURRENT_USER\Software\Auodesk\Autodesk Digital Signatures\IconOverlayEnabled
IconOverlayEnabled = 1 = on
 IconOverlayEnabled = 0 = off
Administrator Productivity
