Fred,
> We do mech. dwgs and have included the rev status in the filename.
I've seen this and it seems to work ok.
> The file is released and uploaded thru netscape to a holding dir.
Ok so far. Do you have seperate directories for projects? Or... Is it one
large directory for the whole shooting match?
> When a change is required we request the file to be downloaded to us.
It seems you work on your local hard drive then. This is probably best from
a speed standpoint, and you don't have to worry about the network dying
quite so much.
> I have been the only one using MDT since R1 but only for models, for the
past
> year we now are using MDT for full design and dwg views. All the ways we
have tried
> have caused some problem when using linked external files, mostly the rev
letter in filename
> and having to download each file, thats why the zip file question.
I think you may have more troubles with the zip thingy. If you use a
particular part on more than one piece of equipment, you will have trouble
when you have to do revisions because now you will have to do revisions to
every zip file that contains a duplicate of the detail in question.
I kind of think that it is best to have things in set places. You say you
have to download a file in order to work on it. This leads me to believe
you don't have access to the subdirectories that contain the original
details and yes, this will cause you a lot of trouble with xrefs. You
really need to have access to all the files. I don't think zip is an
appropriate solution though. Unless they zip them up for you before they
download them. Kind of a dynamic zip kind of thing.
You really need to be playing with real time data or things will get out of
control fast.
> Most people here think the paper copy of the dwg views is all that matters
and if you can not
> see the change don't rev the next assy even if model parts inside the 3D
model assy changes.
We're talking about data here, not a picture. Back in the old days a
drawing was no more than a picture. Today it's different (or should be).
We should be concerned that the data present in a drawing is true, correct
and current, no matter what the picture looks like. By updating the
assembly with a change to a detail you can now check whether the change has
affected any other areas of the drawing before it hits the shop floor. If
you ignore the benefits of this, it will cost you later.
And... while I'm thinking about it...
Have fun,
Dave
