Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Tool Palette Installation
4 REPLIES 4
1071 Views, 4 Replies
Is there a simple way to "install" custom tool palettes: copy the files,
set the file search paths, load the LISP files, check for mapped network
drives, add the TP groups, import the xtc's, etc.?
We have multiple users in multiple office locations using multiple verticals
(Map & Civil3D).
Some sort of installer routine perhaps?
I thought of using the Action Recorder, but apparently it does not work well
with dialog box inputs.
Earl
4 REPLIES 4
>(Map & Civil3D).
Yes, it's entirely possible, and I documented how to do exactly this in my AU
2007 class on installing AutoCAD Architecture 2007.
http://au.autodesk.com/?nd=class&session_id=1181
It's for ACA, and I don't know if it would be directly applicable to C3D/Map,
but I would bet most of the concepts are the same.
Matt
matt@stachoni.com
Thanks Matt,
I will check it out.
Earl
"Matt Stachoni" wrote in message
news:6228449@discussion.autodesk.com...
>verticals
>(Map & Civil3D).
>well
AU
C3D/Map,
Matt
matt@stachoni.com
mikefradette
I have also set up tool palettes for our 30 CAD workstations. I can also re-deploy at the touch of a button. Let me know if you need a hand.
Shneuph
Do you know where in the class you talked about toolpalettes?  It's 1:35:22 long.  Even if it's just after the middle or somthing vague.
Thanks.
My bad.. It was easier than I thought to find.. Got it.  Thanks.
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
Administrator Productivity
