Thanks Matt,
I will check it out.
Earl
"Matt Stachoni" wrote in message
news:6228449@discussion.autodesk.com...
On Thu, 30 Jul 2009 16:15:39 +0000, EarlM wrote:
>Is there a simple way to "install" custom tool palettes: copy the files,
>set the file search paths, load the LISP files, check for mapped network
>drives, add the TP groups, import the xtc's, etc.?
>We have multiple users in multiple office locations using multiple
>verticals
>(Map & Civil3D).
>Some sort of installer routine perhaps?
>I thought of using the Action Recorder, but apparently it does not work
>well
>with dialog box inputs.
Yes, it's entirely possible, and I documented how to do exactly this in my
AU
2007 class on installing AutoCAD Architecture 2007.
http://au.autodesk.com/?nd=class&session_id=1181
It's for ACA, and I don't know if it would be directly applicable to
C3D/Map,
but I would bet most of the concepts are the same.
Matt
matt@stachoni.com
