Had the same problem, I decided to consolidate and network all the ctb,
I made a directories just for ctb's , if you goto tools, options, files
click on printer spooler file path, than pick plot style table search path
and browse to your networked location, I have three ctb's, 11x17, full size
color, full size black,
by keeping them on your network everyone will have the same ctb's I also
locked the files
so only I can control the tables.
did the same with pc3's also,
you can take it one step future and creat a company profile, than copy to
each station,
this will save the paths
good luck
Karl Detrick
Cadd Manager
"Richard binning" wrote in message
news:8021F6905E91A913F73B16DA8FC05544@in.WebX.maYIadrTaRb...
> Map your users to their local drive c:\program files\application name\plot
> styles.
> Now place only your standard ctb's in a network folder and
programmatically
> add
> a shortcut to everyone's local plot styles folder which points to your
> network folder.
> Now users can dump project specific ctbs in their local folder without
> confusing everyone
> else on the network.
> RLB
> "James LeVieux" wrote in message
> news:99299734328CE3BDB0B06A99DF72EF91@in.WebX.maYIadrTaRb...
> > We are an interior firm specializing in restaurant design using r2000.
> > As the CAD Manager I created 7 .ctb files that met our in-house needs.
> Now,
> > as the years go by, there are more than 30 .ctb files in the "Plot
Styles"
> > folder. Some were sent from clients, some where created for a special
> need
> > on a particular project, some appear to be custom-made by users for
> > god-knows-what-reason, some are a complete mystery.
> > I want to shut off access to the "Plot Styles" folder for the users but
I
> > can't since the users may need to be able to dump a .ctb into that
folder
> > for use on particular projects. It would be nice to be able to keep
> project
> > specific .ctb files in the project folder but r2000 does not appear to
> > support this.
> > Any ideas on how to clean up this mess? The only solution I can think
of
> is
> > to shut off access - then make the users come to me so that I can put
the
> > .ctb files in the folder in a coherent manner. I think it would be
nicer
> if
> > AutoCAD would DEFAULT to this main "Plot Styles" folder but allow .ctb
> files
> > to be stored in other locations also. Do releases 2002 or 2004 support
> > this?
> > James LeVieux
