Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
text style standard: ?
21 REPLIES 21
Message 1 of 22
477 Views, 21 Replies
I currently set up two font types for my office, Times New Roman and Arial.
1. Times New Roman for title Block, Drawing Notes like: First Floor Plan.
2. Everything else use Arial.
Any comments for this?
21 REPLIES 21
Message 2 of 22
I use 4 shx files shadow, simplex, ldot, and helv. The below link shows
their usage. The table font/style has been discontinued. (civil work)
http://www.thegrafixshop.com/civildrafter/standards/text.htm
"SMR" wrote in message
news:CDD646040444C2E81BB928DF3B380E94@in.WebX.maYIadrTaRb...
Arial.
Message 3 of 22
I am looking for fonts for Architecture solution. Thanks thought.
"Kevin R. Knox" wrote in message
news:76DFC91117F4D585A2423EF17FBCFBE6@in.WebX.maYIadrTaRb...
> Arial.
Plan.
Message 4 of 22
Arial.
I prefer exactly the opposite. Arial is a sans serif font designed
specifically for titles, and Times is a serif font designed specifically for
body text. I also use lower case for body text because serif lower case is
the fastest and easiest font to read, and there is no longer a speed of
drafting argument for the much harder to read all caps.
Best,
Gordon
Message 5 of 22
I work for a MEP firm, our biggest headaches come from architects who use
non-standard fonts. Everyone has Times New Roman and Ariel, I think your on
the right track. Our office uses Romans as a standard.
Matt
Arial.
Message 6 of 22
SMR wrote in message
Arial.
Our architectural office matches your number one and
for number two we like Stylus.
Mark Major
Message 7 of 22
You mean RomanC/D/S/T?
"Matt" wrote in message
news:EACA6EF25C7DCE8662FBB43CB30C8904@in.WebX.maYIadrTaRb...
on
> Matt
> Arial.
Plan.
Message 8 of 22
Yes, we use Romans
Message 9 of 22
This isn't a new issue. Anyone should know that if they use a nostandard
font, they need to send the font file with the drawing to any outside
consultant.
Up until Acad began to support Windows fonts, everyone had to either a) use
a custom shx font, or b) settle for what came with Acad. Many, if not most,
architects went with a) because they cared about controlling the appearance
of their drawings. And they quickly figured out that they needed to ALWAYS
send all associated support files along with their drawings.
We don't use Windows fonts at all, because up until the current version they
caused God-awful performance problems, and I'm not 100% convinced this has
entirely gone away. After the debacle of Postscript fonts, I'm keeping to
the policy of letting a new feature ride for several releases, to see how it
pans out, before I build any office standards around it. I wasted time in
three consecutive versions because of jumping on the Postscript bandwagon
prematurely.
We continue using the same hand-lettering style custom SHX font that we have
used for years, because we do stock house plans, and it's important to us
that all of our plans are consistent in appearance. If we went with a
Windows font, we still wouldn't put a high priority (if any at all) on being
limited to the most commonly used fonts. We'd pick a font based on our
appearance preferences, with the understanding that it always needs to be
sent along with the drawing, just the same as things have always worked.
Matt wrote in message
on
> Matt
> Arial.
Plan.
Message 10 of 22
RomanS here as well...
on
> Matt
> Arial.
Plan.
Message 11 of 22
I know it's standard but we still come across it. I have to track down fonts
a few times a month, our font directory is pretty full but there is always
an archi out there who wants to make there drawings stand out.
Have a good weekend,
Matt
> consultant.>
Message 12 of 22
Matt, to avoid cluttering up your font folder, put the oddball ones in the
project folder they belong to. That way, Acad will still find them (since
the drawing's folder is always on the search path), and when the job is done
and you archive it away, the fonts will go with it.
news:9EEC3EA441F4066814640EFBBD662930@in.WebX.maYIadrTaRb...
fonts
> Matt
> > consultant.>
Message 13 of 22
Just note that True Type fonts (Times & Arial) have been known to degrade
the performance of AutoDesk products. This is why many of us stick with the
shx fonts (RomanS, D, & T).
John Mayo
Arial.
Message 14 of 22
What does this shx mean? Please clarify this.
"John Mayo" wrote in message
news:76D3517539D1AA926B75596625FB9D4A@in.WebX.maYIadrTaRb...
the
> John Mayo
> Arial.
Plan.
Message 15 of 22
SHX files are the fonts files that are supplied with AutoCAD.
news:20D88A914A9B042903A7E61572A8FB0E@in.WebX.maYIadrTaRb...
degrade
> the
> > John Mayo
> > Arial.
> Plan.
Message 16 of 22
Currently use
Arial for Title stuff
A thickened Arch style font for bold stuff
and a simple Arch font for normal stuff
Moving to
Arial for Titles
RomanD for Bold
RomanS for normal
Arial.
Message 17 of 22
Architecture use?
"John Colby" wrote in message
news:ADE7D48443A2FB7237A9E50050FA0AE4@in.WebX.maYIadrTaRb...
> Currently use
> Moving to
> Arial for Titles
> RomanD for Bold
> RomanS for normal
> Arial.
Plan.
Message 18 of 22
Becarful with TTFs. They no longer have performance issues in viewing and
regens, but if you have lots of text the file size can double.
Arial.
Message 19 of 22
yeah. I personally hate the stylized fonts. we've been using them since long
before I got here, about a year ago a couple people started wanting to use
the RomanS font. Now we're moving towards that direction.
news:85D0482870D422D2ECD21684C6B5F831@in.WebX.maYIadrTaRb...
> Architecture use?
> > Currently use
> > Moving to
> > Arial for Titles
> > RomanD for Bold
> > RomanS for normal
> > Arial.
> Plan.
Message 20 of 22
I must be the oddball old school goof, because I have our standards set at
using the Leroy standards from LDT.
L60, L80, L100, L120 and so on. Leroy styles use a simplex font.
We just finished up a pretty complex Subdivision and had all the signitures
on the original mylar for recording at the County Courthouse and we had a
change in verbage. Easier to use erase w/ spit and leroy the change than to
replot and have to go get all the signitures again. Although spending a 1/2
hour cleanining out a 00 pen was a pain. That reminds me, I should fix the
digital copy to match. (yacks, the only downfall of handdrafting fixes).
Arial.
Administrator Productivity
