Text Formatting box didn't appear. As well I can't even edit my text too. How am I going to do with this problem ? Thank You
AutoCAD version?
Command you want to use with this 'text'? And if you type it then select the 'text' what happens?
LIST command confirms these are TEXT (or MTEXT) objects?
I'm using the Autocrat LT 2009.
Although I've try to create a 'Text Formatting Box' but it doesn't show the Text box at all. And the command line at the bottom shown "can't find Shell Program". What happen to my Autocad LT ? Am I accidentally click something ? Beside from that my "Mtext" also can not edit any annotation. How am I going to do with this.
I did repaired and re-installed for so many times, but I still can't solve this problem.
Your prompt action will much appreciated. Thank you.
Somewhere the Text Editor is no longer being recognized by AutoCAD. Registry Cleaner perhaps?
What does MTEXTED return?
Please remember to check Solved if your question has been answered
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
...and what did you do in case another searches for a similar problem?
