Paul,
My Reg fix stays put once set.
The Registry fix is per user, under the HKEY_CURRENT_USER hive. Once a
new user logs onto that machine, the default settings which activate
that little irritant will come back. Just save the Registry hack to a
.reg file and import it back in when a new user logs on.
Or, better yet, configure a Default Profile on your machine or network
Domain which has this (any many other irritating settings) disabled.
I use a utility called AtomicXP to axe this. Check it out.
Matt
mstachoni@comcast.net
mstachoni@bhhtait.com
On Mon, 10 Feb 2003 07:03:19 -0800, "Paul Kirill"
wrote:
>We are looking down the road at upgrading all the cmputer in the office. By
>the time we upgrade, XP Pro will most likely be the OS of choice. On my
>laptop running XP Pro, I have noticed that the "Passport Wizard" pops up
>quite frequently and unexpectedly. I have found a regedit "fix" on the web,
>but it won't stay fixed. Has anyone else dealt with this problem? I don't
>want all my users to sign on for passport accounts just to make the prompt
>go away...
