Thought I would add just a small note here. The slide manager program you guys are pointing to is a great free slide manager,
however, will not work properly on a 64 bit system. I'm having the same issue on it, and I'm running windows 7 64-bit.
Haven't tried the Dotsoft one or know if it's still available, which means falling back to the orginal way of doing it.
Which takes a really long time if you have alot of slide files as I do.
Straight from the current autocad help file:
entrance.sld
hall.sld
stairs.sld
study.sld
balcony.sld
As an example: CD “c:\slides”
slidelib libraryname < list.txt
For example, if you named your text file areas.txt, you could create a library called house.slb by entering slidelib house < areas.txt. The SLIDELIB utility appends the file extension .slb to the slide library file.
Hope this helps but like I said this takes a really long time for alot of slide files and I hate to type 😕
use a little dos to get all your sld file names...
click start, run, type cmd in the box & click OK
then type in the code...
dir /b /s "[folder containing sld files]\*.sld" > "C:\my slides.txt"
[folder containing sld files] is the path you stored them in plus \*.sld eg "c:\my slide folder\*.sld"
then tap return
then open the txt file in notepad (the txt file is in the root of C:\ and called my slides.txt unless you changed it)
press ctrl & H (to open the replace dialogue)
in the find what box enter the unwanted section of the files address, leave the replace with box empty & click replace all
you should now have the list you required without all the typing
I just learned something from a friend of mine, if you have Windows 7 64 bit Professional Edition, as I do,
then you should have a shortcut to Windows Virtual PC. listed under all programs.
(This is not available on Home Edition as far as I know),
This little beauty actually runs Windows XP , inside Windows 7, more than that it allows all your old programs, that
ran under windows xp to run under this. I've already tested that slide manager you're pointing to on it and now it runs fine.
Hope that helps you and everyone else 🙂
( I know that helped me out lol )
Dude, you're kidding . . . right? This is how we did it back in 1985 when I started in Autocad, when 2 1/2D was the best you could get and AutoCAD 2.8 could fit on a single 5 1/4" single sided single density floppy. AutoDesk should be ashamed of themselves for not having an integrated utility specifically for this purpose. There are other programs out there but I'm having trouble finding a 64bit version
In case anyone is looking, Slide Man is a very nice utility for creating slide libraries or editing them.
http://www.graytechnical.com/software/slide-man/
I hope that helps,
Kyle
Can you please send me a working link for the zip file you mentioned here. I cannot seem to get the link you have shown to take me to the discussion or the ZIP file.
Martin
@Anonymous wrote:
Here is a great, free Slide Manager by Cyrille Fauvel:
http://discussion.autodesk.com/servlet/JiveServlet/download/126-341701-3919905-33457/SldMgr.zip
Daniel J. Altamura, R.A.
Altamura Architectural Consulting
and SoftWorx, Autodesk Authorized Developer
http://partnerproducts.autodesk.com/popups/company.asp?rdid=2139
Try SLD: https://github.com/ADN-DevTech/AutoCAD-Slide-Library-Manager
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
