CAD Managers
CAD Managers
jclaidler
Message 1 of 7 (3,212 Views)
Shrinkwrap for AutoCAD: LISP
3212 Views, 6 Replies
02-11-2011 06:41 AM
Anyone have a LISP routine that will create a border around selected objects?
Lke shrinkwrap?
Thanks.
John Laidler
TravisNave
Message 2 of 7 (3,193 Views)
Re: Shrinkwrap for AutoCAD: LISP
02-11-2011 01:06 PM in reply to: jclaidler
You might also ask that question in the LISP forum.  You might get better results.
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/bd-p/130
Good Luck!
Distinguished Mentor
TerryDotson
Message 3 of 7 (3,185 Views)
02-11-2011 03:37 PM in reply to: jclaidler
Simply draw a loose rectangle around your objects and use the BOUNDARY command, then erase the outer rectangles.
pendean
Message 4 of 7 (3,164 Views)
02-14-2011 05:55 AM in reply to: jclaidler
Like a WIPEOUT?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
jclaidler
Message 5 of 7 (3,157 Views)
02-14-2011 10:48 AM in reply to: jclaidler
Nope, not like WIPEOUT.  Easily stated, I need a line drawn around the outside edges of selected blocks.
John Laidler
New Member
kelley.pearson
Message 6 of 7 (2,555 Views)
08-16-2012 10:39 AM in reply to: jclaidler
Easy. Draw a closed polyline (rough) rectangle just outside your block or any object you want. Then use the BOUNDARY command with lsland detention. Choose Region or Polyline as Object type to create. Pick OK, then Enter if you do not want to select addition interal boundaries. Erase the orginal rough rectangle and outer boudary on it. You're left with your object plus the inner boundary shrinkwrap. No Lisp needed. Done! :smileyhappy:
New Member
jefferypsanders
Message 7 of 7 (1,586 Views)
09-24-2013 02:51 PM in reply to: jclaidler
I posted a cheap attempt at shrinkwrapping using the boundary command here:
http://www.jefferypsanders.com/autolisp.html
JPS
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
