Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Settings for Drawing Status bar
9 REPLIES 9
Message 1 of 10
SKSS
1260 Views, 9 Replies
Where are the settings for the drawing status bar saved?  (The ones that say Grid, Ortho, Osnap, etc...)  They don't seemed to be saved to workspaces or to profiles or to the cui.  I'm trying to set up a consistent UI for multiple users.
Thanks!
9 REPLIES 9
Message 2 of 10
jggerth1
in reply to: SKSS
Are you asking for settings for the _values_ stored and set by those controls, or settings as in what's displayed?
for many, if not all, the values are drawing specific.
Message 3 of 10
SKSS
in reply to: jggerth1
The settings for what's displayed.
Message 4 of 10
jggerth1
in reply to: SKSS
AFAIK, it's not documented, but would probably be registry entries only.
If you're on Subscription -- or ADN, that might be a good place to ask.
Message 5 of 10
SKSS
in reply to: SKSS
OK.  Thanks!
Message 6 of 10
rkmcswain
in reply to: SKSS
It's documented in the help files.
Find the system variable each button modifies (for example: F8 = Orthomode), then look up that sysvar.
They are either saved in the registry, drawing, or not saved at all.
Message 7 of 10
SKSS
in reply to: SKSS
Thanks but I'm not looking for how to set the system variable, I'm looking for how to control the display of the status toggles.  For instance, we don't do 3D work in Cad so I would like to remove the 3D Osnap toggle from our standard UI.
Message 8 of 10
dmfrazier
in reply to: SKSS
For what it's worth, it appears they are stored in the registry.
For AutoCAD 2010, "vanilla" profile:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.0\ACAD-8005:409\Profiles\<<VANILLA>>\StatusBar\Application
For AutoCAD 2013, "vanilla" profile:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\ACAD-B001:409\Profiles\<<vanilla>>\StatusBar\Application
(I just searched the registry for "StatusBar".)
Message 9 of 10
SKSS
in reply to: SKSS
That's the answer!  I can also find and edit that string in the .arg file. Thanks!
Message 10 of 10
dmfrazier
in reply to: SKSS
You certainly can (as an ARG file is essentially a renamed REG file).
As long as you import the edited ARG, the edits will take effect.
Administrator Productivity
