i am in the process of preparing to upgrade to Autocad Mechanical 2014 (from 2011) for my company and I would like to set the default printer to "Default Windows System Printer" instead of the "none" currently selected for all users. When i do, the paper size changes and the border and title block templates no longer fit of the page. the current paper size is not listed in the dropdown for the default printer. attached is a current and changed screen shot of the settings. Does anyone know how to correct this issue?
thanks for the thoughts but i had tried that as well. I believe the issue is the actual paper size we use in the case of this A1 size is listed as ISO A1 (841.00mm x 594.00mm) but when i change the printer this paper size is no longer available in the dropdown list. we draw everything on a full size paper and then scale down the print to fit on the paper size of the printer (most of the time 11" x 17").
I am assuming that you have already setup your default windows printer to have all the correct settings. Then created a .pc3 or other plot settings file to distribute to all machines on the network, or be prepared to manualy set each one up by sitting down in front of them. You may also have to drop a couple of points into paperspace and or modelspace at the approximate size of your standard border so that both of these spaces have an "extents" to enable the default to plot extents from the template.
