CAD Managers
CAD Managers
Active Contributor
mrobertson
Message 1 of 4 (1,094 Views)
Running Land Desktop 2008 with C3D 2012 under current subsription
1094 Views, 3 Replies
02-08-2012 11:11 AM
Is it possible to run Land Desktop 2008 with Civil 3D 2012 under the same subscription contract?
Will Autodesk provide separate network license files or will a new 2012 version license file work for both?
Thank you
Subscription only allows for you to run your current release (2012) and up to three versions back (2009) only.  Your 2008 product, if upgraded thru Subscription has had its lease expired.  If you wish to file for an exception, you should probably contact your Reseller.
TravisNave
Message 2 of 4 (1,093 Views)
Re: Running Land Desktop 2008 with C3D 2012 under current subsription
02-08-2012 11:15 AM in reply to: mrobertson
JGerth
Message 3 of 4 (1,064 Views)
02-14-2012 07:48 AM in reply to: TravisNave
 >>Your 2008 product, if upgraded thru Subscription has had its license revoked.
FTFY - Since it's a perpeptual use license, not a lease.  The revocation is, as you correctly noted, a side effect of  upgrading, whether via subscritpion (which permits use of three versions back) or simple upgradinng..  A new purchase of 2012 would not result in the loss of the 2008 license, but a straight purchase would cost somewhat more than an upgrade from 2008 to 202.
Active Contributor
mrobertson
Message 4 of 4 (970 Views)
04-26-2012 02:55 PM in reply to: TravisNave
With our resellers help we were able to get an extension to the end of the year.
Thank you for the replies.
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
