Mark,
I've used sysprep and RIS (Remote Installation Services) on my Win2K network
extensively, with varying degrees of success.
In general, if the video or disk subsystems are different, I do automated
installs from either a network source or (more preferably) from a CD. For
automating CD installs, check out the deploy.cab file for info on automating
installs using a winnt.sif file.
The reason I prefer CD over a network resource is that I can reformat and
repartition the hard disk only by using the CD/winnt.sif option. As long as the
source CD has SP2 on it, and is bootable, you're golden. You can create a Win2K
SP2 bootable CD-ROM by "slipstreaming" SP2 onto a HD copy of the original /i386
folder, then burn it to CD. Use the info here:
http://www.thetechguide.com/win2kbootcd/
Because Win2K has much better hardware support out of the box, I tend to let the
install routing work out the details. At the very least it will boot and you'll
have a decent VGA screen to work with. The ATI Rage Pro chipset may or may not
have intrinsic Win2K support (I think it came out after Win2K did).
One thing to do would be to use the VGA drivers when making the initial master
image, which should take that out of the equation.
I have several master images here, but because our hardware is pretty similar I
can use RIS to recreate a new workstation if required, pretty quickly. However,
because of all of the latest service packs for the application solftware, I
still have to spend quite a bit of time tweaking the machines to bringt hem up
to speed.
In the end, I don't think it's worth it, because of the overhead in setting up
RIS/sysprep images and having to maintain those images with constant software
updates.
Matt
mstachoni@comcast.net
mstachoni@beyerdesign.com
On Sun, 14 Apr 2002 22:03:15 -0700, Mark Evinger
wrote:
>OK, so I just suffered through an aborted rollout of W2k on dissimilar
>hardware. Created master disk image on CPQ Deskpro EN SFF PIII/933
>w/NVIDIA TNT PRO video chipset. Attempting restore on machines w/ATI
>Rage Pro chipset. Safemode and VGA mode refuse to boot. RestoreConsole
>lets me disable services at boot; started w/AGP440.sys and escalated
>from there to darn near every boot-time service in attempt to get this
>machine to boot the GUI.
>I now know more about sysprep.exe and ERD issues than I ever wanted to.
>Are mass Windows 2000 PRO rollouts best attempted *only* on all
>identical hardware? It seems like the sysprep -pnp option is not
>forcing the hardware rescan at the right time. I can live with creating
>multiple install images for the OS, but is it possible to salvage the
>current master image without reworking/reinstalling all the
>applications?
>We are putting off the W2k rollout until all the machines can be
>booted. The mix of chipsets is unavoidable until next year when all
>the equipment goes off lease and I can finally standardize all equipment
>to one model line. Aiieeee!!
> Stop it!!! You are driving me *mad*!!
>Anyone care to lend hindsight advice to a mass W2K setup? (and ditching
>all the current equipement for new, standard stuff is not an option )
