Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Message 1 of 18
2628 Views, 17 Replies
"ZE" command
I have a CAD user that insists on only using one method of zooming, and suddenly that method stopped working when we started having database issues. Can anyone explain why a command would suddenly stop working?
17 REPLIES 17
Message 2 of 18
ZE is not a command, but most likely a macro or keyboard shortcut that calls the "zoom" (and then)
"extents" command
the file (or path to it) containing the shortcut was probably lost during the "database issues".
wrote in message news:5978426@discussion.autodesk.com...
working?
Message 3 of 18
I dunno, but since apparently your CAD user stopped working long ago, I guess
the ZE command figured it did not have to work anymore either.
Matt
mstachoni@verizon.net
mstachoni@bhhtait.com
Message 4 of 18
Here are some keyboard shortcuts that I use. Put it in your acad.lsp file
and make sure to put it in your "startup suite" and then load.
;;;===== Nested Command Aliases =====
(defun C:zw ()(command "zoom" "window")(princ))
(defun C:ze ()(command "zoom" "extents")(princ))
(defun C:zx ()(command "zoom" ".8x")(princ))
(defun C:zd ()(command "zoom" "dynamic")(princ))
(defun C:zi()(command "zoom" "1.5x")(princ))
(defun C:zo()(command "zoom" ".5x")(princ))
(defun C:zp()(command "zoom" "P")(princ))
(defun C:leadr()(command "leadr")(princ))
(defun C:bkvlays()(command "bkvlays")(princ))
(defun t:CHT() (command "chtext")(princ))
(defun t:datestamp() (command "datestamp")(princ))
(defun t:apptype() (command "apptype")(princ))
(defun C:if() (command "imageframe" "off" "")
;;; ===== AutoLoad =====
"Matt Stachoni" wrote in message
news:5978586@discussion.autodesk.com...
guess
Matt
Message 5 of 18
C O Jones
Rick,
I am familiar with the "(defun C:..." but what is the
"(defun t:..." function?
CO
Message 6 of 18
dxarhoulakos
Thats interesting. I haven't used those zoom commands in years...since i got a wheel mouse.
Message 7 of 18
I don't know what that means, I got this from our old IT guy who left the
firm. He is a whiz at this stuff.
Rick
wrote in message news:5979507@discussion.autodesk.com...
Rick,
CO
Message 8 of 18
On Fri, 11 Jul 2008 15:33:25 +0000, C O Jones <> wrote:
>Rick,
What's weirer is that the "commands" those functions are calling aren't real
AutoCAD commands.
Matt
Message 9 of 18
This one's especially useful as a shortcut.
news:5979848@discussion.autodesk.com...
AutoCAD commands.
Message 10 of 18
I think this one is more useful
to access this you need to type
(t:datestamp)
Jamie
"Jason Piercey" wrote in message
news:5979834@discussion.autodesk.com...
AutoCAD commands.
Message 11 of 18
Anything with (defun C: code line, the command name following C: can be used
as if it's a real AutoCAD command.
But anything without the C: will need to be used as a lisp function
surrounded with parenthesis.
So in order to use the command (defun t:name-of-command, at the AutoCAD
command prompt, you'll have to type (t:name-of-command).
Some programmers would rather use f: instead of t: to represent a lisp
function command name instead of an actual command which by default Autolisp
uses C: for.
So looks like all those (defun t: lisp functions are calling other lisp
functions which have already be loaded elsewhere in the file.
Paul
"C O Jones" wrote in message news:5979507@discussion.autodesk.com...
> Rick,
> Thanks,
> CO
Message 12 of 18
In the "old days" when third party developers only had LISP to work with,
they would "tag" their commands with a prefix like ABC:command - where ABC
was their authorized autodesk developer tag, or one they gave themselves.
This helped avoid problems that would crop up where you might create an
inhouse function called "plotstamp", and then a little later buy a program
from someone else that might also have a function defined as "plotstamp" and
then a year later, Autodesk decides to include a command called "plotstamp".
SO you might tag yours with x:plotstamp, the "real" developer might tag
theirs with "abc:plotstamp" and autodesk just leaves it at "plotstamp" - no
conflicts and expected results every time... It's a good practice, but never
remember to do it...
Rick,
CO
Message 13 of 18
Yep, I remember those good old days too when autodesk developer network
called that interoperability programming.
But I guess that push never got off the ground.
Paul
"pkirill" wrote in message
news:5984495@discussion.autodesk.com...
> and
> "plotstamp".
> no
> never
> Rick,
> Thanks,
> CO
Message 14 of 18
Laxtor
Ever since using a wacom tablet I no longer have the benefit of a wheel mouse so have to do things the old fashioned way with a keyboard.
Although I am obviously using far to many key presses every time I zoom Z [Space] or [Return] and then e, p or w to zoom extents, previous or window. I mean what a klutz using a whole extra key press every time I zoom.
Message 15 of 18
FYI: You don't need to use "W". Windowing is implied.
wrote in message news:5987138@discussion.autodesk.com...
Message 16 of 18
dxarhoulakos
thats interesting. anyone else use a tablet for CAD?
i've used it effectivily for photoshop, and illustrator, but haven't been able to grasp while using CAD.
i guess i can't get over the lacf of wheel scrolling...which is useless in photoshop and illustrator anyway...
Message 17 of 18
I've used a tablet since R10.
wrote in message news:5987328@discussion.autodesk.com...
Message 18 of 18
Are you using the pen in autocad? My wacom tablets have always come with
a wheel mouse, but if you prefer to draft with the pen I suppose you would
not have that option...
Hello Laxtor,
> keyboard.
> every time I zoom.
Administrator Productivity
