You need to "Remove boundaries" (the inner circle) after you do an "Add:
Pick points" for the wall.
Daniel J. Altamura, R.A.
Altamura Architectural Consulting
and SoftWorx, Autodesk Authorized Developer
http://partnerproducts.autodesk.com/popups/company.asp?rdid=2139
"JC" wrote in message
news:5453876@discussion.autodesk.com...
I've got a tube steel block (basically a circle in a circle as a
block)inside a wall.
I want to hatch the wall, but not inside the tube steel.
Right now no matter which "island" option I choose, it gets me outside
the tube steel, not inside the section itself, but it hatches in the
interior of the tube steel.
Is there a way to get acad to not want to hatch inside a "doubly closed"
block?
Jonathan
